Today I tried to start a 1 cylinder diesel engine (Lombardini) that had been sitting unused in the shed for 8 years. The fuel injection system primed easily and appeared to work fine. It had steady pulsations of fuel from the end of line at the injector connection. The engine would fire with ether but never run wen the starting fluid burned off.
I pulled the injector out and reconnected to the fuel injection system. When I checked for the spray pattern it did not spray any fuel. I assume the injector is clogged. I tried spraying break cleaner in the injector and that did not appear to help. How do I clean this or make it work again?
