farmhand f11 loader pump questions
mrjata
New User
I have a 3020 with a farmhand f11 POS loader on it with the pump on the 1000 rpm shaft on the belly. How do I get the stupid pump off the shaft? I cant find/see and cupler or pins to press out/off. All there is a is a chain, and a short lever to keep the pump from rotating.
Putting a 148 on the 4020 and won't need this and will sell it but have to get the pump off first! HELP
It has to be an aftermarket pump/John Deere issue as the F-11 never used a 1K PTO pump.
Oh, and I'd take your POS loader in a New York minute. :>)
Allan
Those pump(s) just slide on/off.Unhook the chain and pull it off.Simple as 'falling off a log'.As Allen says "I'll take that POS any day!"The F-11 will lift more wt and higher than the JD.The pto pump keeps your rear outlets freed up and saves a lot of wear/tear on the tractors pump.
A 148 on a 4020 will make a nice outfit, but it won't be any better than the F11 on your 3020. If I didn't already have an F11, I'd be contacting you.
Thanks for all the replies. I just needed something that was easier detachable. I won't be using it all the time, maybe.
What kind of price do you guys think I should ask for the loader? Can you see good enough in the pictures?
IF that is a "good" welding repair, paint it up with Chevy orange engine paint and she'll bring $1500.
Allan
(quoted from post at 10:24:33 05/02/14) IF that is a "good" welding repair, paint it up with Chevy orange engine paint and she'll bring $1500.
Allan
Chevy orange. I was kind of curious about what might be a fairly good match. My F11 has almost NO paint, except for where it got covered in oil.
You'll be glad you got rid of that hunk of junk no down pressure pos when you get that other loader ya the f11 will lift higher but that's the only thing better about it even with the double acting cylinders they still won't give enough down pressure to smash a mouse . Not to mention no crawling over the rear axle to get on. and faster hydraulics . And you can turn the tractor with the loader down if you need to and the loader will move with the tractor not just keep going straight .
