Paul L Cochran
New User
I have a Ford 1994 1715 diesel and have maintained it with oil changes & filter changes, fuel filter changes and it currently has 750 hours in operation. I only use it for mowing and have a 5 ft, mower bed which works extremely well. It starts great, idles, no ruff running but recently started to lose power and then regains but bleeds off again. I can run it pretty well on the level ground but any uphill or incline it will bleed off and come to a stop then after a few minutes will regain and take off again but then will slowly die off and the cycle continues. I have replaced the diesel fuel cleaned the gas tank, lines and there are no obstruction. Also, replaced the fuel filter and added some injector cleaner but still have the problem. It does seem to run a little better with the hand throttle? I sure need some pointers on what to do next!
Paul
Paul
