electrical system for 1964 2010ru john deere
kirtis
New User
was just wondering if system is all 12v and had also heard that could be reverse ground? Any info would help and thanks
(quoted from post at 16:13:29 03/28/14)
(quoted from post at 18:01:10 03/28/14) 12 volt with positive ground.
Jim
I owned a 1965 2010 RU diesel for 28 years. It was 12 volt negative ground.
Greg
Your 2010 didn't come from the factory as negative ground? 2010's came with a generator with 12 VOLT positive ground
The rest of the story is that a ballast resistor is used to drop the battery's 12 volts to the coil while it's running, which is bypassed for a hotter spark while cranking.
