coil tine harrow teeth
cih
New User
Looking to replace harrow teeth on my 2210 JD field cult. Has anybody used shoup replacement teeth? They are less expensive but do they last as long. They are made in the US. They replace JD
#n236890 THANKS FOR ANY INFO.
They are a little softer than the JD tines. They seems to wear a little faster in sandy ground but don't seem to break as much. Kind of a toss up to me.
Depends on how cheap you can buy the JD teeth. For a full set I can usually get the local JD dealer to discount them a little bit.
IF you have to give full boat then I would consider the Shoup tines.
