lights on trailer
I just bought a gooseneck trailer that needs a little TLC! Anyway I will be using it at night a lot to load my tractor so Im gonna mount 2 55 watt work lights on the front. Will the 12volt hot in the plug carry enough amperage to run the lights when the trailer is plugged into the truck or do I need to run another wire from the battery to the back of the truck? I will have a switch on the light it self. I don't want to buy another battery for the trailer if I don't have to.
The plug and receptacle ought to handle that approximately 9 amps (110 watts/12.6 or so volts) assuming the plug is one of those typical 7 pole RV units (or a unit designed for 20 or so amps to be safe). However if it were me Id use 12 Gauge wire from the battery back to the auxiliary pin on the receptacle and, of course, protect with a 20 amp overcurrent protection device right at the battery. AS ALWAYS when wiring trailers A GOOD GROUND IS MOST IMPORTANT and if insufficient causes all sorts of problems.
John T
your 2 55watt halogen lamps will make about 1000 lumins each. Lasting about 350hours. LED producing the same output will last about 15000 hours, and suck 10% of the power,(or about one amp) for 2. Jim
i have these on mine for backing up at night and
tailgaters
I did the same with my trailer. Problem I ran into was the ground wire in the plug overheating and burning the wire. I inatalled an additional ground by attaching a wire to the gooseneck and another direct to the truck hitch. Ran a 10 gauge wire with a spade lug connector and solved the ground problem.
Gene
LED light is very hard to see with, flashlights look like it is bright but gust can't hardly see anythinf in that light.
