Anonymous-0
When you have loaded your tractor do you leave it in gear? I heard that shucking back and forth on two or three teeth is bad and neutral is better.
Gotta put a little weight on the drive tires.(quoted from post at 21:17:49 03/13/14) probably up there cus it never gets unloaded.lol
(quoted from post at 19:09:35 03/13/14) Lock the brakes and put in low gear.Nothing there to hurt from being in gear.Look how hard there jerked around when being used,hauling is nothing.
Being in neutral makes the tractor jerk on your chains every time you stop and take off.If a chain breaks or a binder breaks there's nothing to keep the tractor from rolling off the truck.It's just another safety precaution.
(quoted from post at 19:22:28 03/13/14) I have seen more than one tractor that started from jerking back and forth . Mag tractors no way in he!! Do I leave them in gear.
