drylakemachine
New User
Been here awhile,but just reading.It's been 5-6 years setting,
replaced a tube,plus cleaning up the rim.New carb kit,still no start.Rotor was rusted on .so it cracked getting it off.New ign. kit ordered.I noticed looking at the wiring dia.that the bat . terminal on the coil goes to the dist.Is this because of the positive ground?
What is the reason for the positive ground?
Thought about an altenator,but allI've seen are neg. ground.
Or is the starter the issue here?
The oil pressure gauge didn't work either,what's the T fitting for in the oil pressure line.
One more question ,will the remote cylinder circuit run a log splitter with the control on the splitter and the tractor remote handle held open(engaged)?
thanks jim
thanks jim
