Massey 35 Loader frustration
BrianRBM
I was messing around with my loader thinking of taking it off but changed my mind. I hooked the back end of the frame around the axels OK but now I"m having a tough time lining up the two bolts that are under the front end that bolt into the tractor. I"m about a half inch out and need the tractor to go ahead by this amount but it moves the loader frame too. I must have been up and down twenty times foolin" with this and its still not close. Does anyone have advice on lining this thing up. Many thanks as my bones are getting old.
A com-a-long etc. Are the bolts on the rear still loose?? If not they need to be loose till all the bolts are in so thing cam shift. Or if that does not work you might try blocking the loader up and take the bolts out of the rear and then you can move the tractor. I have done a good many loaders and they can be fun to get on and off
Yes........I do have the rear bolts loose but maybe not enough. I was thinking tonight that maybe a come-a-long will help. Like you say....its been fun. Thanks for your reply.
