Question on F-20 clutch pressure plate
SweetFeet
My husband has a question, if anyone can help out. Our tractor manual does not specify...
Does anyone know the proper procedure for adjusting the clutch release levers on an F-20 pressure plate?
I did also post this question on the IH forum.
Saw you over there on the Farmall forum. The thing I found out, on my 'H', is that the bench-adjustment procedure didn't work, I had to adjust it in-place on the tractor, and then it worked just fine. In the cse of the 'H', it is easy, can be done from underneath the tractor.
Other thing, I fonund an IH clutch sdjustment manual on eBay, but I don't see it dicsusses F-20's.
Someone posted this a while back , maybe it will help
