After the furnace shuts down, water is still moving thru the system. Which means that the well pump and pressure tank are moving water 24/7. The solenoid valve is in the line exiting the furnace. I googled the valve, and it said that it could also be a control panel problem. If I turn off the electrical power and the water to the furnace, would I be asking for trouble by removing the screws that hold the valve together, so that I can see if it is dirty and needs cleaning?
Of course this had to happen on the weekend, but at least it is still giving us heat.
Thank you
Steve
Thank you
Steve
