So here is a picture of the pump.I was wondering if the DBG in the top left corner of the tag is the model number?Was wanting to order seal kit and maybe a repair manual.Also after taking the little timing plate off and finding no black ground pieces.Am I still headed in the right direction in taking the pump off? Another few things we have found to be odd is. (1) I removed the fuel supply line to the top of the injector pump crank tractor then stop bubbles come out the fitting.(2) When everything is hooked up and you crank tractor then stop.I hear noises in the fuel tank.So was wondering if this is a sign the pump is having problems? Thanks again for your time.Blaine
