Anyone burn honeysuckle?
OliverGuy
I cut a couple wheelbarrows of 4 to 6 inch around pieces last year. They seem really heavy still, but I can't find any btu output data. I'm going to try some tonight. I thought I would try to burn some, it's thick through all the fence rows here and is basically a weed. It feels so heavy that maybe it's just as good or better than my normal types of wood? Anyone burn this before?
I haven't burned it in a stove but have set the vines afire in fence rows and it burned hot and fast like gas was poured on it.
if it burns like popular an.old guy told me to burn that in the spring when you need some heat but not a real hot fire. i burn all my junk wood in the fall and spring when i need some heat but not a lot
It grows really healthy in this virgin ground in fence rows! It's mostly not that big, but a few of the buggers grow well.
The past couple of years I've cleaned a bunch of it around the timber. At the beginning just piled it up and burnt everything. Decided it was a waste, so bought a good self-feeding chipper, a 28 ton splitter and have since fed all the big stuff thru the wood stove. Pretty light wood when it gets dry so yours is wet. Need to split and let it age for 6 months or so. Otherwise no problem.
