anybody run 23.1-34 tractor tires
Brian806
Anybody run 23.1-34 tractor tires? Thinking about putting a set on a 806 wheatland! Because it has little short stubby axles! Wont be used to plow has no 3pt hitch!
Got a JD 4440 with them on it right now. They are a common combine tire and can usually be found cheap. They are about the same height as a 18.4 x 38 but just wider.
Yes- they will match in height. My 2470 had 23.1 inside, and 18.4 duals with the belled rim. They"re duals on my M2 combine now.
