Another 886 question
scotty-mn
There is an antifreeze leak from the oil cooler to the cast elbow how are these connected?
I don't know, but you might of wanted to pass on that tractor if it is held together with bungie cords. Why is there a step there?
Yep, o-rings. There are two short pipes with o-rings on each end. Drain coolant, remove bolts from other end of cooler, slid it out and renew the o-rings.
