Bought an older house a while back and one of the bathroom ceiling heaters wouldn't work. The house is about 50 years old and ungrounded, but was built by a builder at the time for himself, so it is very well constructed and the wiring for the time is top-notch.
In checking the ceiling heater, it is on its own circuit, but the spring loaded, soldered thermal break on the heater itself had turned loose (right side of pic) - I resoldered it and it worked fine for a solid hour, so I can't find anything that specifically caused it.
I got to thinking later though - could that original solder connection have been very precise for the load?? And my resoldering it could have made it unsafe due to a thicker solder now??
Is it more appropriate to replace that with a fuse or breaker? Or do they still make those spring loaded soldered breaks?? Or should I just replace the whole thing due to an old-fashioned design?? Obviously, the whole heater is on a circuit breaker already, so I'm not sure why this was built into the heater, too??
<a href="http://s130.photobucket.com/user/case600lp/media/permanent/20140201_200440.jpg.html" target="_blank">
Thanks for any advice,
HH
