Mystery Farmall Part on Ebay
Bryce Frazier
Hi all it's Bryce, I was just scrolling around on Ebay and I saw this add. What is it? I know that one part of what is in the picture hooks to the Bell Housing, and then to the tube behind it. It is the same setup that both of my C-294 Belly plows use, but what is the other thing in the picture? Looks like it might have a handle on it, and maybe it mounts to the axle? Bryce
Looks like it mounts to the axle and the long arm goes up front and hooks to the lift all arms like would be used to lift the plow. Or maybe I'm looking at the wrong part.
here is how part of the parts mount.
That looks like the linkage that was on a mounted plow on a Super C that I owned briefly in 2012. It was quite a chore to mount, I imagine, but all I had to do was dismount it. I sold the plow a while after the tractor and I didn't save any pictures of the linkage but here is a link to an old topic showing the tractor and plow after I got them home.
Zach
Super C
THE LEVEER ON THE OUTSIDE TILTS THE PLOW FORWARD OR BACKWARD FOR PLOWING AND LEVELING. THE LONG ONE TO THE REAR LIFTS THE PLOW
Dang, that listing is for Bancroft, Mi. I could have went and looked at it for you. Only 6-7 miles away.
Rick
Well, I missed it because I thought it said 4 days, and it only said 4 hours.... Oh well! Here is what the guys said:
the other piece bolts 2 rear axle housing and will lift cultivators or 3 point hitch or many other things . ( this is factory original not fabricated ) thanks Jerry
After looking at the pictures of your guys mounted plows, they are very different than the one that it on my C. I have an arm that runs from one of the cylinders on the left side of the tractor, all the way back to the axle, then it crosses the back of the tractor to the right side where the arm that lifts the plow is. Then it is simply chained to the plow. The plow uses that same frame where it hooks to the bell housing, and then the tube. It has two flip over locks, makes it really easy to hook up, because you leave the V frame under it and just ram into the plow in reverse, it will make the plow straight with the tractor, then you just jump down and flip both the locks over, and DONE! The only down side, is that between both of my C-294 plows, I don't have one of the leveling arms, you can see where it would go in the second picture. I have been trying to come up with dimensions, but no one seems to have them! Thanks, Bryce
