This message is a reply to an archived post by Kentb of SWMO on May 31, 2009 at 15:31:04.
The original subject was "Re: bad engine Coil draining battery ??".
I hav checked all fuses for trace bt nothing is changing,ran engine with negative terminal out to check if alternator is gud and it run bt voltage wont go above 10v when m running the engine and keeps dying off...pls. help
