(quoted from post at 04:33:21 01/30/14)
I also use a lot of them. Wipe a little grease on each side and torque them down.
(quoted from post at 21:40:35 01/29/14) Hobo, if you have ever installed a nagneto on an airplane engine, you would have learned why the grease. Timing mags every couple years is a lot easier if the gasket is greasd on one side. Bare gasket will seal on both sides and be impossible to rotate the mag without distroying the gasket. Same applies to tractor magnetos.
Gene
(quoted from post at 09:49:46 01/30/14) I don't think I'd use grease on all gaskets, but the old 50's and 60's MOTOR manuals instructed one to grease the gaskets when assembling the 3 and 4 speed transmissions.
The ONLY head gasket that I have ever reused was made from solid copper. It can be heated to a dull red, which will make it expand, and then be used--but only one or two times.(quoted from post at 15:40:03 01/30/14) I use "Copper Coat" on most gaskets, and have
had no problems.
On another subject: I was looking for Wisconsin
Engine parts, on Flea-Bay, and was surprised to
find seller's listing used Head gaskets. Who buys
used head gaskets? Why buy used head gaskets when
you can get them new at NAPA !
(quoted from post at 19:24:00 01/30/14) In over fifty years as a T&D Maker and Mechanic, I have made literally hundreds of gaskets. I can not remember ever making a gasket out of anything but gasket material, but may have fabricated a few when I was 12 or 13 years old--and didn't know better LOL!
I have a large assortment of gasket material from .010--1/8" and have fabricated many different size hole punches from 2" down to 1/64" and have made up many small engine carburetor gaskets.
I just finished refurbishing a Gravely G16 Lawn Tractor and I made every gasket except the head and exhaust gaskets.
I have--in a pinch or non-available-- made head gaskets out of copper!!
I can see how "cardboard" would make a gasket, and I am sure some have lasted for many years--just not the way I work.
With some small gaskets I would coat the metal surface with a light film of oil and carefully place the gasket material to the surface and press. This would leave a nearly perfect pattern and I could cut gasket without guessing.
As for sealing with gasket material, I don't, unless the surface can't be dressed or made perfectly flat.
