Another Question, How To Set a Two Way Plow?
Bryce Frazier
Hi all it's me again. I just had an interesting thought. I know that to set up a three point plow on a tractor, you have to set the tractor on blocks, and then do some adjustments. HOWEVER, how would you go about setting up a three point TWO WAY plow on a tractor? I assume that you would make the plow level on the three point, and then put one side of the tractor on blocks to mark the other side of the plow? This Case plow that I have has a middle notch for transport, and 5 or 6 in each direction so to speak. What do I do? Bryce
Lift arms level side to side, top link so plow sits level front to back when down. Stops on plow set so plow sits level when in furrow. Fine tune top link and stops in field. Plow should be level both ways when plowing.
