Look what passed me today
1349
Location
NW Oklahoma
Driving in N Oklahoma....this was coming up behind me, I thought iit looked weird so I slowed down to let it pass....I saw the frame splice from what used to be a truck to this racecar hauler? trailer. Apparently running it front wheel drive because there was nothing driving the rear wheels. Weird looking rig. I couldnt help grabbing the phone and taking a pic.
That is wierd, great pic, nice and flat out there no snow, looks like they have enough street lights too! thanks for posting it.
I saw a few trucks like that in Germany 20 years ago. Front wheel drive, rear axle controlled hydraulically so the bed could be lowered right down to the street. Forklifts could drive right up on them without a dock or ramp to load, then raise the rear axle to the driving position and go. Pretty neat idea.
When I was racing, back in the 1970's, I saw the same thing someone had done with an Olds Toronado. That was when the Toro was big, with the 455 ci engine.
They'd cut the Toro off behind the front seats, adapted a pickup cab rear panel onto it, and fabricated frame rails joining it to a tilt bed tandem axle trailer.
Out local MTD (city buses) have some Ford people movers that are set up like that. It keeps the floor real low so people can get in easier. There"s a 4x4 transfer case on the transmission, blocked off where the rear driveshaft would connect, and just uses the front driveshaft. Silly setup, but I guess it works.
I wonder how long the front drive terrain lasts like that?? I remember years ago my grandfather who never had a 4wd truck asked my dad if you disconnected the driveshaft to the rear end, could you drive your truck with the front axles? Or in 4wd with no power to the rear end, just the front end.
The problem with this kind of setup is that the front differential on a four wheel drive runs on the back side of the ring gear because a front differential is just a rear differential is flipped over.
When flipped over the ring and pinion are driving on the same thrust face as when right side up. No geometry changes other than which side of the drive wheel hits the road!.
It could be a Toronado drop in!! Jim
All I will say is it wouldn't be worth a hoot
on snow coverd roads in pa. Loaded.....
That's not exactly true. Lots of front ring & pinions are reverse cut to be run in the front. Dana axles use them all the time, especially on fords.
