Will a 530 clutch fork fit in a 520? I thought there was an update for the 520 clutch. I have had trouble with the clutch when using it a lot when mowing. It doesn"t want to disengage. The 30 series fixed that problem with a different fork that is adjustable through removable plates. Thanks
JD parts book for anything and a cross reference.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
If the 520 is the same as the 620 series
you would have to have a black dash model
or a late series 520 for it to have the same
clutch parts as a 530.. Sealed beamed headlamps
Black dash, upgraded clutch & I think a improved
Power steering. I am sure there is someone here
that know's this info 100% for sure.
The only change in those clutches was to assist when shifting gears. The fork is spring loaded so as to provide a neutral spot to let the pulley rotate very slowly then you pull back on the handle to engage the brake against the spring pressure. It is detailed in one of the books.
