(quoted from post at 21:01:19 01/23/14)
Electric will be all usable btu's . LP can be input but with venting will be less, maybe as low as 8,000 btu's depending on efficiency.
Please don't think of using an unvented heater indoors.
(quoted from post at 18:01:19 01/23/14) Electric will be all usable btu's . LP can be input but with venting will be less, maybe as low as 8,000 btu's depending on efficiency. Please don't think of using an unvented heater indoors.
(quoted from post at 09:32:05 01/24/14) MikeM,
Moisture means your windows and places you have water is too cold. Not to mention too air tight. Let in a little cold air and crank up the heat. Things will dry out.
Heat pumps may cause your moisture problem, cold heat.
(quoted from post at 06:32:05 01/24/14) MikeM,
(quoted from post at 15:06:55 01/24/14) Building code in your area maybe ?
Many places no such codes exist.
