Would a thermostat fail in OPEN position?
rabbit-1
'00 Chevy Blazer, 4.3L engine... Engine temperature in the 140 to 150 range, heater barely working... Could the thermostat have failed in the open position?
3 Other Blazers in the family running 190+, heaters working well...
There is a thermostat on the market that if it fails it will always fail in the open position.I put them in my vehicles to be safe. If they stuck closed I'am not sure my wife would stop before it got to hot.
funny you should ask this.. my 2000 F250 had minimal heat at best..NEW to me a year now. I was told could be that very problem.. I drained and flushed the system and replaced thermostat and just because I put in a new heater core.. Works perfect.. I guess as Nancy said would rather it be open then stay closed..
Had one on 77 chev that never reached max temp. Took it out and compared with new one over teakettle in steam. They both opened together but the new one closed fast the old one hung open a long time. The new one brought the temp up to spec.
Later Bob
Check your coolant level, check the thermostat and if both are okay, next stop would be the intake gaskets.
Allan
Just went thru that with a 2000 S-10.
Have flushed it twice since new (leftover) That orange anti-freeze (GM) is the problem. Inside of radiator has a layer of ???? No heat, but engine overheating.
Replace thermostat and flush. This makes the forth set of thermostats, antifreeze and flush. Container of orange anti. says 150,000 miles.My truck turned 115,000 miles. Think they lied!
Yeah they can and do fail open, or they can physically break too. It doesnt have to fail wide open either, it can be that it just doesnt seal shut all the way and in cold weather the engine wont heat all the way up. Take a close look at it when you get it out, you may spot the trouble.
Engine overheating and heater not putting out anything?
Me thinks you should look at your coolant pump.
jt
Yes, it can stick open. I have a 97 Jimmy that the gauge reads about 155 and heats good, plugged a scanner in to it and it's 195 so gauge is off. Some of those little Blazers would plug the heater core bad, take hoses off engine and flush with a garden hose. Some of the radiator caps leaked down the side of the rad. tank and sooner or later it's gonna need intake gaskits
I think there used to be a serv bulletin that said the cause of the dex cool antifreeze sludge was air getting in to it, never had any trouble with mine.
Same problem with my 2000 GMC Sonoma.
You flush it, change thermostat and anti-freeze and a year later the anti-freeze has rust in it.
There"s a bulletin on this problem for Chevrolet/ GMC .Just google it.
