Eric in IL
The wife informed me last evening her 2010 V.W. Jetta had a headlight out. I went for a look-see. I started the car and the messages on the dash concerning bad bulbs lasted about 5 minutes it seemed. I had eight non-working lights on various areas of the body.
After about 90 minutes of troubleshooting, I found the plastic on the brake light fuse partially melted (fuse was still good). The plastic on the fuse holder showed signs heat also. I grabbed a new fuse, smeared the legs with dielectric grease then re-installed. Presto, let there be light !
So here is the question, how can a bad connection on a brake light fuse also effect :
RF low beam
RF high beam
RF turn lamp
RR reverse lamp
LR tail lamp
LR turn lamp
Rear liscense plate lamps
I have always hated chasing electrical failures !! Sorry for the rant.
RF low beam
RF high beam
RF turn lamp
RR reverse lamp
LR tail lamp
LR turn lamp
