OT - Snow Plow on GMC Sonoma
1130Leo
I am thinking of putting a Snow Plow on my 4x4 Sonoma to plow the driveway at my cabin, will not be taking it anywhere else, will a Sonoma handle a 7'6 Myers blade??? I know it's big, but since I won't be driving it further than the driveway as long as it will hold up for 5 or 6 years I'd be happy. Any opinions here?
Western builds a lightweight plow for half ton applications. Plastic moldboard with steel cutting edge (I think). google western plows.
I know it's big, I could always cut the sides off to make it 6' or 6'6" wide. It's in really good shape and has the hydraulics on it to swing side to side as well. Plus, it's one of those "the price is right" deals....
I think your main problem is going to be that the second you lift that plow, the suspension under the front of the truck is going to squash right down. It's going to be HARD on the truck and it might not last the 5-6 years you want to get out of it.
If you cut it down it should be okay for what you want to do. I know a guy that had one on a ford ranger and I asked him how it did and he said it did real good till we got a real heavy wet snow then the front end would want to push away from the angle of the plow. I know another guy that has had the same plow on two dakotas and said they each have done fine. Saw another one last week going down the road on an s10 blazer approx a 92.
You will not want to make it any narrower as the truck is 80in wide and you want the plowed snow away from the trucks wheels
it might be ok for your drive but id remove it right after, when i installed a new western 7'6 plow on my truck i weighed the whole assembly, plow and mounting tiped the scales at 875 lbs, thats a whale of a lot of weight for a sonoma front end!
Exterior Measurements
WIDTH 5 ft. 7.9 in. (67.9 in.) HEIGHT 5 ft. 2 in. (62 in.)
LENGTH 15 ft. 10.6 in. (190.6 in.) GROUND CLEARANCE 0 ft. 7.2 in. (7.2 in.)
FRONT TRACK 4 ft. 6.4 in. (54.4 in.) REAR TRACK 4 ft. 6.6 in. (54.6 in.)
WHEEL BASE 9 ft. 0.3 in. (108.3 in.)
If i were to do this, I would definately make sure it's a little wider than the wheels. Still debating. The only reason I'm thinking of the Sonoma is because I have it, and do not use it anymore. Just shoveled the snow out of my driveway at the cabin this weekend, do not want to do that again...
I have two 7'6" western blades on 1/2 ton trucks. One is an older chevy with a solid front axle and beefed up leaf springs so it supports the weight nicely. The 2nd is a 97 half ton ford and with the plow lifted the front suspension bottoms out and makes nasty noises.
A sonoma is a "mini" truck and needs a plow designed for that size frame. Simply cutting the larger blade down will help with weight but it will still be too heavy. The plows designed for the 1/4 ton trucks have a lighter undercarriage, shorter/narrower/lighter blade, lighter trip springs, etc.
I think it would be better in a lot of ways to trade the Sonoma for a 3/4 ton heavy duty truck or a one ton truck.
I have never been lucky in pushing equipment beyond its design limits. I have a vision of the front end collapsing right after the frame buckles on that Sonoma.
You'd be better off with a larger truck.
Someone might be happy to trade their gas guzzling 3/4 ton
whatever for a smaller Sonoma they can run on the road.
Win-win. Specially if you can find one the mount is designed for.
Another though would be to re-sell the plow and buy one of the
"homeowner" cheapies. They can be bought new for about the
price of a good used full size plow.
If you have to use it, see if you can get the weigh down.
I ended up finding a "Snow Bear" plow it only weighs around 250 lbs, and is in great shape, should fit my needs just fine. It was even cheaper than the other one, and it should not destroy the truck.
