4 1/2 pistons
molinegb
Does anyone know of what used 4 1/2 pistons? 6 inch piston with 1 1/2 pin diameter and 3 inch compression height. The originals are Buda cast pistons but are in bad shape.
Massey 55's had a 4 1/2 x 6" engine, and the 1080 and 1085 had a 4 1/2 x 5" B&S, and the T-9 and IH650 series used a 4 1/2 x 5 1/2" set of jugs....
AC 45 grader was 4 7/16"bore and 5 7/16" stroke in the Buda based 516cid 6 cylinder engine.
Should be the same for 344 cid 4 cylinders too.
John Deere B from 1941 to 1946 ? had 4.5" cast iron pistons originally. Not sure if the after market has any replacements for them either ?
