Kubota L4150 hydraulics
Anonymous-0
I'm working on a customers 4320(clutch job) and he asks me if I would take a look at this Kubota, yea why not. I haven't looked at it yet will have to get the 4320 done first. So any known problems with this model, its his landlords with a loader and the loader doesn't lift forgot to ask if the power steering or three point work. Will have to see if there is at least an operator manual. thanks chris
50 series is way on back like over 20 years old. Most common would be loss of prime in the hydraulic pump due to air leak or clogged suction filter. You get it in my e-mail is open.
just like jm. said 20+ year old tractor. only common problem I have had is unrelated to hyds. main shifts forks bend mostly from guy grabbing gears like it was a sports car.but I have seen the o-ring where the suction pipe bolts to hyd pump crack and suck air.
