20f problems
snook3000
New User
I have a Massey Ferguson 20f.Industrial tractor.The steering shaft broke just below the steering wheel,problem is they no longer make the steering column for that model.I have called everywhere looking for new or used.any info would be helpfully.it has power steering.thank you.
Remove the part and have it welded probably the quickest and cheapest fix as getting the correct piece mite not be easy
This is what I call southern engineering, I'm certain the shaft goes through a sleeve, is there enough room inside that sleeve to put a pipe over the shaft and weld each end of the pipe to the shaft, you would have to come up with some way to hold the shaft together so it would be straight when you well each end of the pipe, this might be an option if you can't find the shaft.
Thanks all for the info,I believe I found one,had been in a fire so shaft should still be good.if not then I am going to have old one welded.thanks again for the help.
