I got the Cub Cadet 782 out to blow snow last night. It ran good for about 5 to 7 minutes and then lost all rpm. It would still idle. When I shut the blower off, the engine speed did not increase noticably. I limped it back to the garage. I took off the air cleaner housing, thinking it might be plugged. That did not help. A little while later it picked up speed. I took it out and the scenario repeated itself. I played with the governor linkage moving it by hand, but that did not make much difference. Is it possible that I have a slug of ice in the fuel system and the fuel flow is too slow to give full rpm? This is unleaded regular without ethanol. Usually I have the garage warmed up before trying to use it in the winter. Thinking about getting a little isopropyl to put in it tonight. First time used this winter for blowing. Any other ideas?
