Fuel line heat wrap
I am wondering if anyone makes a fuel line heat wrap for diesels that will prevent ice crystals and line freeze up from cold temps?
This product is not a simple resistor in a plastic insulator. It is a thermistor material that regulates its own temperature and goes not exceed its rated temp even if insulated or wrapped upon itself. If put into a fuel tank, or wrapped on the lines with a rubber or foam cover it would do the job. It would be a great experiment to give it a whirl. Jim
One source
Don't know why the water line wrap that you use to prevent water pipes from freezing wouldn't work. Can get this at Lowes, Home Depot, etc...
Have you tried any of the products out there that help stop this? Power Service makes one and have used isopropyl to stop line freeze up.
years ago i was going to get a fuel line with a 12 volt heat line embedded in the line,can get different lenths, i just googled it and it came up with it, rod
