Richard G.
Mounting a tire on my 51 Case VAC and it is 70 degrees and 100% humidity.
Yall keep that "cool" stuff up north and west if you don't mind. My shop floor looks like I sprayed water on it.
Richard in NW SC
Thanks for rubbing it in. Haven't been able to get warm in two days now. Moved bales off the field yesterday,'bout froze. Been hauling manure this morning. Same thing. It's starting to freeze down to the concrete.
Conditions like you described is when the ingiton on my truck screwed up. Moisture got under the distributor. So far the new cap, rotor and a little grease to seal cap is working. A few days ago we had your conditions. Today, it turned to snow and 20.
Shop cat's water dish sits about twenty inches below a heat lamp in the shop. Half inch of solid ice on top of the water this morning here in north Colorado.
Just came in the house from the shop. Been doing some repairs on an antique wood heater. It is 71 degrees outside. I had to sweep my shop floor twice to get the puddles of condensation out the door.
Water was dripping off my 17 Model T onto the floor.
Sorry, I just had to rub it in some more.
Richard in NW SC
