I have a John Deere 3020 which has a lighting problem. First it is blowing the fuse going to ground on the left battery on the positive terminal. SO it is getting 24 volts to the lights on the 2 outer lights. The 2 inner lights have no power. I thought something must be grounded causing it to blow the fuse so I found there was a ground from the positive side of left battery to ground, so I found it was coming from the starter on the positive post, so I took it to a repair shop where they told me the starter was ok. The only thing else I can think of is I had a mechanic change the fuel gauge as it was not working. He said he had to ground it to the opposite ground. I wonder if this could cause the problem? Do you have any ideas or what I should be checking to isolate this problem?
Thank You
Rick
Thank You
Rick
