Zachary Hoyt
I bought a Snapper self propelled mower with a 7 hp B&S Intek at
an auction. I did not hear it run. It was sitting in the rain and
then rode home in the rain on a trailer. When I got it home I
checked the gas and oil and began pulling the rope, it began to
squirt water out of the muffler. After a while it began to try to
run and eventually it got to where it would run for several
seconds and then die. I did this three times or so and then quit.
Today I went out to try again and found that while I could turn
the engine over by turning the blade I was not able to turn it with
the rope. I spun it several times by the blade and then it
loosened up. Now it pulls freely but does not run, the plug gets
wet with gas. It has 85 psi compression according to my tester.
Is that too low to start or should I be looking at the spark? Any
advice will be much appreciated.
Zach
Zach
