M F 1105 water pump removal
Anonymous-0
If you guys answer all my questions I,ll never have to buy a shop manual. So my big beast is now in my yard. Couldn,t even see my old Oliver 1355 parked behind it.The only glitch on the 1105 is I need to install a new water pump. Does anyone know if I can replace the water pump WITHOUT removing the radiator? Almost looks like there is enough space on the big bugger to do it.
Confounded in Quebec
I did that repair myself and I am not a pro-mechanic, You CAN remove and replace the water pump without removing the radiator.
You must of course remove the fan but after that you are good to go. I recommend having somebody help you because that sucker is pretty heavy and you do not want to damage the radiator.
Good luck
