Russ from MN
Location
Bemidji MN
We might go look at a HD 2145, it's a fixer-upper. If I can buy it cheap enough I might go for it. Anything in particular to look for? The owner says it needs a starter, it could be as simple as the seat switch, but its a gamble!
I would price it as a nonrunner because you might think a used started will cure things and find the motor is shot after you put a starter on it.
We just went and looked at it, it's complete, looks OK, just doesn't turn over with the starter, but it does with a wrench. New tires, new belt, new blades, it might be worth the $50 he's asking. It has an Onan engine and a long narrow battery like I have never had on a lawn tractor before, looks expensive!
