FORD 7000 water from exhaust
Gavin Kedar
New User
I have a Ford 7000. Recently on start up, some water blows out from exhaust. Tractor is shedded, so no rain gets in. Is that a sign of porous block, or head gasket (had a new gasket about 3 Yrs ago). Thanks in advance. Regards.
Moisture is a byproduct of combustion. Condenses in the exhaust system until it gets warm. Could this be the problem? Especially since we"re having colder conditions, especially overnight. Keep a watch on your radiator fluid - if it"s not going down, you"re probably OK.
Agree with rabbit. Colder it gets outside the more of it and longer it takes to quit. If worried, catch some and if you can look past the soot, if no green no problem....assuming you have AF in your coolant.
Mark
Thanks, Texasmark & rabbit. Will check that out. I am from N Queensland, so our weather is warming up here. :) Regards.
