Yep about every week or so depending on area heated/ furnace BTU ,etc.(quoted from post at 09:11:33 10/24/13) I have been heating with 100# for 10 years now, the coldest winter I change one every 7 days, cook and dry clothes with LP too.
(quoted from post at 23:58:58 10/23/13) NEVER, NEVER, NEVER, put a propane tank next to a furnace, the radiant & convective heat from the furnace will cause the propane tank to build up excessive pressure to the point where it either vents through the safety relief valve or it ruptures the over-pressure burst disc. Either way you are venting propane gas into the house right next to an open flame source . . . and KABOOM! you've just blown your house off the map, and in all probability with you and your family inside.
