Allis Chalmers b 3 point conversion (Help)
Can anyone help? I have just installed a new 3 point
hitch conversion on my Allis Chalmers B and it does
not function. I am sure there is air in the system
but can not get it out. Also does anybody know the
recommended fluid to use after in installing this
conversion kit?
Universal Hy-tran fluid is what is normally used in the transmission/hydraulic system. If you are using the original pump&valve system it should work. If you are using a larger cylinder you may run low on fluid when 3 point is lifted.
