(quoted from post at 14:47:29 10/16/13) WELL SAID let them try feeding the world with out RoundUp.
(quoted from post at 14:22:14 10/17/13) Modern farming is allowing us to "feed the world" How do you think we are able to support the set asides and CRP ground.
The nation is losing farmland at the rate of 2 acres a minute to urban sprawl.
So there won't be room to mess around with antiquated methods that were left behind because they didn't produce efficiently.
As for your other concerns, maybe you need to do some research about markets demand and how they play into the supply of commodities.
We import beef that's true but we also export quite a bit. We export stuff that sells well in other countries and we import stuff that the American consumer prefers, which is mostly hamburger and steak. Price is also a big factor in the amount of imports, McD's likes to get the cheapest stuff it can.
Same for milk. We import a bit but we also export a lot. Demand for certain products plays a part in that.
Quit turning food into fuels and we'd have more? There is still a decent carryover expected in the corn market, noticed corn is flirting with $4.
(quoted from post at 17:43:10 10/17/13) I find it funny that the same people that claim we need to "feed the world" don't even want to feed fellow hungry Americans. It's hypocritical to get your undies in a wad over Organics not feeding the world and then stating that we should cut food stamps and let Americans starve...
The world can feed itself. There's tens of thousands of acres sitting idle in Russia and Africa as we speak. If you're so concerned about feeding the world, load up your 9n and head to Africa.
(quoted from post at 21:33:14 10/17/13) Since. the original point of contention was about Roundup it would be better to look at grain markets anyway and we are considered the world's breadbasket due to being such a large exporter of grains.
Find me some starving Americans. Our poor have a major obesity problem, not the working poor, but our welfare class. You twist the idea of personal responsibility into "let them starve". That's intellectually dishonest to start with.
(quoted from post at 04:56:01 10/18/13)
They may be fat, but they're nutritionally deficient. The garbage pumped out by major food manufacturers isn't fit for pigs. The poor have no access to "real" food in many areas of the cities and have to buy from fast food restaurants or convenience stores.
(quoted from post at 06:23:28 10/18/13) If you removed all GMO technology from the table, all pesticides, all chemical fertilizer... especially fertilizer... you can bet your bottom dollar that there wouldn't be enough food to go around, even if ethanol was removed from the equation. You'd be talking about taking agricultural production back to 1940's levels when the planet could barely feed itself then with two and a half billion people. We're at 7 today and projected for 9 billion in 40 more years time... and we're still paving over our best farm land everywhere you look. Something has to give...
Even if there was technically enough food to feed everyone.... the cost of that food would make it unavailable to some and that some would undoubtedly be a larger number than it is today.
I also challenge the notion outright that 'organic' is more sustainable. You're trading a system most often of reduced/minimum/no tillage and a couple of passes with a sprayer for a system of conventional tillage, multiple cultivations and significantly reduced yields. If you were looking at the energy equation of petroleum inputs per tonne of crop yield I suspect it would be a good deal lower for 'conventional' agriculture vs 'organic' agriculture. When one of the stated goals of organic is consuming less non renewable resources... I think it fails flatly in that regard.
Rod
Are you trying to make us believe that only organic farmers use manure?Plus the soil needs more than just dry chemical fertilizer in the long run.
(quoted from post at 04:56:01 10/18/13)Find me some starving Americans. Our poor have a major obesity problem, not the working poor, but our welfare class. You twist the idea of personal responsibility into "let them starve". That's intellectually dishonest to start with.
Don't get me wrong, the problem lays with the people unwilling to better themselves. My point was that you can't cast the "feed the world" stone at Organics, but then want to let food stamps go away. That's hypocritical.
Fact is, something like 40% of the food in this country is wasted somewhere between harvest and the table. Next time you're out at a restaurant, look at all the food left on plates at empty tables. Take a peek into the dumpsters behind the restaurant and the supermarket. Organics are not standing in the way of feeding the world.
(quoted from post at 02:06:36 10/19/13)Are you trying to make us believe that only organic farmers use manure?Plus the soil needs more than just dry chemical fertilizer in the long run.
How many millions of bushels of chicken manure are applied to conventional farms every year, what about the billions of gallons of pig and cow manure? What about the conventional guys that throw some alfalfa in the rotation?
