1953 Ford NAA Golden Jubilee
I have a 1953 Ford NAA Golden Jubilee that while in a downhill slop the transmission locks up. I can jack up the front of the tractor and rock the tractor back and forth and it unlocks. Runs fine on level ground but as soon as I go downhill it locks up again. If you have any idea of what maybe rough, or how to fix it, I would appreciated hearing from you.
Theres a lot of pressure on gears if the tractor is stopped downhill.May be nothing wrong.My 640 has done it with the baler on a down hill stop.
I would check the pinion gears/bearings out. I have seen a bad bearing let the pinion float forward and lock the transmission in two gears.
