Need help identifying replacement eletrical connector baler
In a moment of stupidity I accedently ripped the power cord for our bale monitor off the tractor.. I need to replace the end and can"t find the connector anywhere was hoping you guys may be able to send me in the right direction on line or in a store.. It is the power supply cord for a gehl round baler monitor. Local dealer wants 120 for cord and all.. I just need the plug. It has three plugs on it and screws into the monitor it also splits in two. I have added pics.. If you know where I can get one please let me know..
These things are always hard to find. You can try Allied Electronics (online) and with a little luck you may find it. They have literally hundreds of different styles of these plugs. There are numbers on it, you may have to clean it up and get a magnifying glass but they are there. Do some google searches on those numbers, sometimes that helps. Unless it's a really big supplier you won't find many who stock them, too many variables.
Yep same connector on a Hesston or Case IH monitor. Also same as a Case IH planter monitor. Be prepared to pay well. I bought 2 sets last spring just the Female end that you have pictured. With pins and complete housing it spoiled 120$
Does it come apart so you can reattatch the wires? Or did the terminals come out with the wires and can they be reinserted? Mark
It's an AMP brand, like Tx Jim pictured Deere used it in the cab for alot of accessories, as did other tractor manufacturers. Make sure you get the right wires in the right spot the first time, you most have really yanked on it, since the wires are hard to get out of the connector with the special tool. chris
