Honda Motor
Animal
We have a 13 horse Honda motor on a bale wrapper, and it sucked the choke butterfly off of the stem that operates it, so we got a new carb,,but now it has a vacuum leak at the bottom of the carb flange. Do they make a thicker gasket for them or can I make one that will work? It looks like their is a passage that goes to the bottom of the carb, for maybe heat release or something, at any rate the two round ports are not sealing, has anyone else had to deal with this?
Animal,
I would try hi temp RTV. Coat both sides of gasket, let it sit for 30 minutes. Should work.
I just put a starter on my 13 hp honda. Took 3 days, but I like it after the job is done. Didn't like doing the job.
George
