ford 2000 numbers stamped on hood
Bob Glass
New User
I need to have a tractor rebuilt,it is hard to read the stamped numbers on the side of the block .i did find these inside the hood trac.# 234441 model b1012c unit 9031b engine 8m30a transmission 8l28b rear axle 8m17b hyd pump 8ms0b hyd lift 9a9b . i am not sure if a couple of the numbers are zero's or theyu are the letter O . i am getting rising oil levels in the crank case and have not added any oil at all lately . bad rings ?
Is your Hyd pump mounted to the engine block ? If so , It's the seal on the pump shaft , it's leaking hyd oil into the engine ......
Or if it's a diesel it could be leaking diesel from the pump seal? or even a thermo syphon starting aid?
Sam
