I'm putting my mower deck back together after replacing 2 destroyed blade driver bearings. Can't find a definitive answer anywhere on what the nut torque should be on a 1/2", zinc plated, grade 5 bolt and nylon lock nut. They are the bolts that mount the bearing assembly to the deck. I've seen everything from 45 ft. lbs. to 150 ft. lbs.. I locked the nuts down at 100#. I'm just a bit concerned that might be a tad too much for a 1/2" bolt and don't want this thing coming apart 250 miles from here where I use it on a food plot. Would anyone know what the torque spec for the nut should be? Am I over? Or under? Or should I just quit being picky about a mounting bolt and leave it as is at 100#? Thanks!
