Got to get my daughter's Durango brakes working before I can
mess with tractors again so I need some help. I put in new pads
and had the rotors turned. It would feel ok stopping at lower
speeds but above 50 and it took to long to stop. Pedal would go
to the floor if you held it down while trying to stop. I bleed the
old fluid out and that didn't help any. Tonight I put a new master
cylinder in it and now they will pump up with the engine off but
as soon as you start it they go to the floor again. I've bled them
in the correct order several times and have used 2 qt's. of brake
fluid trying to bleed them down. I am about out of ideas if
anyone has a solution it would greatly be appreciated.
