Got The Auger Raised
super99
I hooked the JD 70 back onto the Westfield 8x61 auger, took the IH400 with the loader and picked the auger up about 18". The 70 raised it right up about 1/2 throttle. I should probably drill 2 new holes and move the stop so it won't go down so far. Thanks for the suggestions. Chris
Just be sure if you do that it will not keep the transport height at too much to move it under power lines, trees and the like. Or make it too unstable for tipping for moveing.
Be careful transporting it if you move the stop up. It will get more tippy and could hit powerlines.
