I have a zero turn called the TANK--HEAVY duty made by CUB CADET--Industrial model. It has the 23 HP Honda.
To start the brake has to be set--it pushes in on a plunger--switch. The switch went bad and I am 68 and don't like to have to set the brake to start. Anyway the switch has 4 wires. I jumped across two of them and it will start right up---the BAD PART is that the starter won't disengage until I pull the jumper wire.
Any ideas that don't require a new switch?????????
