706 hyd ports
Cory Bennett
New User
Hi I'm trying this again, couldn't find the first post so sorry for the duplicate if there is one. New to this forum or any forum. I have a Farmall 706 with a Farmhand f11 loader on her that i stil use almost every day at the farm. Was wanting to take the hyd pump off the pto (because i have to take it off to run the 540 for bush hog or post hole digger ect). Want to know if I can plumb into the factory pump and return circut to run the loader. I can still use the farmhand valves just need pump supply and return circuit. She only has 1 set of remotes
Yes . BUT you will have to install either a second remote valve or you will have to find a two face valve and a power beyond plate then you can run off the tractor Hyd.'s . NOW the big question is how good is the pump on the tractor ?? IF it is getting a little tired then you may want to upgrade the pump to a 15 GPM pump. and see what kind of pressure the tractor is set at and see what the PTO pump is putting out for GPM and pressure . The most you can go on GPM is 18 GPM , BUT the filter is only rated at 14 GPM . At one time there was a company that made a adapter to stack two filters together and that way you were suppose to get 28 GPM flow thru the filter . Myself i did not like it as i always felt that it was to easy to gret knocked off if you got stuck like the guys do around here . So before you get all carried away have the GPM of the PTo pump and pressure checked as i am sure that it puts out more then the stock tractor system does and you may have a vary slow working loader with out a lot of lift .
Thanks for the info. I was worried about flow rate of the tractor pump compared to the pto pump. I will definatlycheck the flows. Thanks for the help
