Has anyone ever run into a situation where simply changing the hydraulic fluid fixed a hydraulic problem?
I can't see how it would be possible that the fluid would be so bad that it won't flow, but doesn't ruin the pump in the process.
As long as it's liquid and slippery, pretty much anything can be hydraulic fluid. Even water would work if not for the lack of lubrication. Water held in suspension by modern hydraulic fluid works nearly as well as pure new hydraulic fluid. At least, there isn't enough difference in how they perform for you to notice.
